Re: Farmall A conversion
Posted by Owen Aaland on May 14, 2013 at 20:01:55 from (216.47.35.129):
In Reply to: Farmall A conversion posted by WV Farmall on May 14, 2013 at 16:42:45:
If you still have the magneto and a separate coil it has been converted to battery ignition using the magneto to furnish the points and distributor for the secondary wiring. The magneto coil is disconnected inside and the external coil is attached to the terminal that would normally be for grounding the mag to shut off the engine. Sometimes the magneto condenser is used or it also is disconnected and another one is added at the coil. Use one or the other, not both. The external wiring should be the same as a normal battery ignition distributor.
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
