Re: SC starter ring-gear replacement
Posted by Central Illinois on May 14, 2013 at 20:23:38 from (75.107.154.66):
In Reply to: SC starter ring-gear replacement posted by BoonvilleKid on May 12, 2013 at 23:01:17:
I've put several ring gears on over the years and I usually just heat evenly with a torch to remove the ring gear and then do the same to put the new one back on. It doesn't need to be cherry red, just warm. Keep making slow circles with the torch and they will move. I also use a hammer and a brass punch and gently tap on the old one to remove it and tap on the new one to make for sure it is fully seated.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
