My grandpa swore the best baler tractor ever was our IH 656 Hydro. We had a New Holland baler behind it that would really make the tractor bog down if you got her into a big windrow or some wet hay.
Before we got rid of the baler we did use the 7120 with it. The 18 speed trans gave you the perfect speed. Plus it kept him out of the sun and heat. Not good on old farmers with sun spots and breathing problems.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
