Re: Super A front axle
Posted by old on May 16, 2013 at 07:55:54 from (209.86.226.27):
In Reply to: Super A front axle posted by Adrian Billheimer on May 16, 2013 at 07:35:42:
Only way that would hold up long is if you can weld a sleeve over it. What you would need to do is weld it on being sure to grind a V into it them slide a sleeve over it and then weld it on.
If your close enough to me I have a front axle off an A laying around that might work
