Re: Super mta diesel issue
Posted by Janicholson on May 16, 2013 at 10:59:47 from (74.60.94.18):
In Reply to: Super mta diesel issue posted by Cheryl-m on May 16, 2013 at 08:29:56:
D282 is possibly on to the issue. If you filled it that is incorrect. it needs 2.5 inches below the bottom of the neck to be correct. If full it will puke out. If the cores are covered by an inch or so it is correct. Jim
