The stock 6 volt coil will work fine. Simply wire a generic Chrysler style ballast resistor in series with the coil primary and you'll be good.
The diode is to prevent the alternator from backfeeding the coil when you shut off the ignition. Without the diode (or a current-limiting generator warning lamp) you won't be able to shut down the engine by turning off the ignition switch.
Flipping the generator bracket will work for the 10SI. You'll need a bit of threaded rod (or a full threaded bolt) and a few nuts to make a new pivot shaft however.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
