Re: IHC 684 alternator problems
Posted by Janicholson on May 16, 2013 at 21:08:12 from (74.60.94.18):
In Reply to: Re: IHC 684 alternator problems posted by gleanerguy on May 16, 2013 at 12:34:46:
Auto parts do cary the Nissan alt. O do not recommend a one wire setup, they often drain the battery when not used regularly, and do not start charging till RPMs come up. The 3 wire setup is the same as they were used in a car. very reliable and an easy install. The Bob M diagrams show the process. Jim
