Re: Super A front axle
Posted by Pete in Holland MI on May 17, 2013 at 06:26:49 from (198.36.94.35):
In Reply to: Super A front axle posted by Adrian Billheimer on May 16, 2013 at 07:35:42:
It stands to reason that if the pin and bushing are worn, then there could be more fore/aft movement to the axle, thus enabling the force of the axle to bear on the outer end of the broken tube, rather than the entire length.
Suggest looking at the pin diameter and bore thru the axle & bushings, and make repairs here too.
True......as an old guy told me once: There are people with welders who do not hold a "welding" license, and only a "pilot's" license. For all they know how to do is "pile-it" on. There are many ways a poorly welded joint can be weaker than the original without proper techniques.
Pete
