Re: farmall C low oil pressure
Posted by CNKS on May 17, 2013 at 18:48:08 from (216.144.104.128):
In Reply to: Re: farmall C low oil pressure posted by dougct on May 17, 2013 at 18:10:35:
The plate wears or gets warped and doesn't produce as much pressure. It's a common problem. Take the pump apart and check the plate for flatness and wear. The gasket(s) provide the clearance for the rotating part of it.
