Re: 560 crankshaft seal tool
Posted by Jim Naden on May 18, 2013 at 06:15:27 from (12.74.49.115):
In Reply to: 560 crankshaft seal tool posted by ziemerj on May 17, 2013 at 17:49:43:
Are you needing the crank seal driver or the rear main cap seal installer?
Don't have to have either one but the crank seal driver and installation sleeve makes that job much easier.
I've had limited luck with the cap seal installers. As CNKS said, lube them up and push them in, do not trim. It is most important on the rear main cap to have dowels to align the seal bores when you install the cap. Sealant applied between the cap and block as prescribed in the manual will go a long way to prevent leakage.
