Re: 806 governor not opening
Posted by pete 23 on May 18, 2013 at 18:27:06 from (74.47.40.242):
In Reply to: Re: 806 governor not opening posted by Bob2 Martin on May 18, 2013 at 14:56:22:
The plug for regulator is located right on top of the transfer pump. The end of pump the two lines run in and out. It has shims under it but if it is that low the spring is probably fatigued or broken. Fact is I have an old RD pump laying out in the shed on the farm place with the spring robbed out of it for that very reason, about 30 years ago. Of course it is a gear pump so may be plum worn out but worth a try on the spring.
