Start a new thread on this issue so more will join the discussion. Either can be done. Cracks in that location are common, and usually not fatal. Overlapping steel threaded tapered plugs and grinding flat then paint is usually a very clean approach to a repair. Others have used a mechanical bolted on patch covering the crack (after two small holes are drilled at the very ends of the crack to stop its propagation. Others have cleaned the area for 2 inches on each side and on the ends, then used a thin first layer of JB weld covered by a mesh of fiberglass when uncured, then covered with another thin coat to blend in. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
