Posted by CNKS on May 19, 2013 at 08:11:24 from (216.144.104.128):
In Reply to: First Farmall posted by Kevin Little on May 19, 2013 at 05:28:02:
The 3 point is aftermarket. Although I can't see it in the picture, the 3 point should be bolted to the inside clamps on the axle housings. Factory 3 points (not available for the H) bolt to the frame about where the axle housings are attached. Some people have made ones like that. Although it can be used that way, most front cultivator cylinders are mounted between the movable part of the cultivator and the clamps on the rear axle. There is a square piece bolted to the axle clamp that has a hole in top.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
