Assuming no problems with the alternator/regulator wiring, the problem is a bad regulator.
Regulator wiring checks:
- Continuity between regulator terminal F and alternator F - Continuity between regulator terminal 2 and alternator R - With ignition "on" there should be +12 volts at both regulator terminals 3 and 4.
Also there must be a SOLID solid ground at the regulator (the relay base, not just the reg mounting bracket).
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
