Re: cub update from my other post
Posted by sgtbull on May 19, 2013 at 10:29:37 from (163.191.228.254):
In Reply to: cub update from my other post posted by ericlb on May 19, 2013 at 08:05:42:
Get yourself a good J-4 magneto and you'll not have to pull it home again, even if the battery fries completely. Even a weak battery will start a tractor on a mag if it has enough umpf to turn it over... but that's not always true with distributors. Sometimes the starter draws too much juice and it results in a weak spark w/ a dist. coil set up. The magneto's impulse drive will make adequate spark, even it you have to resort to handcranking.
