The relay will not close until charging voltage closes it. Until that point the red lamp activates the field current. The other unit in regulator is the actual regulating part. The points carry the field current and have to be sparkly clean. When alt starts charging those points open when reaching adjujsted voltage setting to cut field current, then close again as soon as voltage drops . It does this hundreds of times a second that is why they are called vibrating regulating systems. Electronic regulator do this with solid state components and they used to preach to us that this could take place as high as 7 thousand times a second. I never tried counting it. Good wires, good connections, including grounds essential on either kind.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
