Re: 12/4X38 Tires
Posted by rustyfarmall on May 19, 2013 at 14:05:02 from (216.248.71.226):
In Reply to: 12/4X38 Tires posted by S/C BOB on May 19, 2013 at 13:22:12:
Depending on how you use the tractor, 4 ply should be just fine. If the tractor is being used for heavy work, or has a loader on it, then you should probably consider going to 6 ply. BUT! 12.4x38 is too SMALL for that tractor. An M/SM should have 13.6x38.
Measure the width of the rims. An 11 inch wide rim needs a 13.6.
If the rims measure just 10 inches wide, then a 12.4 will work, but that M should have minimum 11 inch wide rims.
