Cool info. The plug will have two spade terminals. One will be labeled L the other S (if only one, the other is obvious. The S terminal should be connected directly to the Stud terminal. (short wire with an insulated female spade connector on the plug end, and a ring terminal on the other. the wire can be 14gauge. The L terminal goes to one of the following: a light bulb from a marker light,or dash light, a diode with the band marked end toward the alternator, or a 10 ohm 10 watt resistor. (any of these will do). The other end of your choice of the above is connected to the ignition at the key side of the resistor (if it has one) or the coil supply side if not. This component keeps the tractor from running when shut off. It is in the system as a dash idiot light and is mandatory. This wire can also be 14 gauge. A 10ga wire goes from the big stud to the amp meter. It attaches to the side of the amp meter not connected to the starter relay. If the lights work, make sure that the amp meter moves to discharge (left) if they are turned on with the tractor shut off. If the gauge noves to the charge side, switch all wires from one side to the other. this will make it show charge and discharge correctly. Good luck, Jim
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea
... [Read Article]
Latest Ad:
[More Ads]
