Re: Carburetor issue with Farmall H
Posted by GordoSD on May 19, 2013 at 16:59:37 from (216.106.250.104):
In Reply to: Carburetor issue with Farmall H posted by VMcnew on May 19, 2013 at 13:24:05:
There is also a drain port to keep the fuel from filling up the intake. Yours is plugged. Fix that when you fix the float/needle valve problem.
