Re: Farmall SH Fuel Flow and Timing
Posted by sflem849 on May 19, 2013 at 18:21:20 from (69.197.84.39):
In Reply to: Farmall SH Fuel Flow and Timing posted by IAtractorKid on May 19, 2013 at 05:47:01:
I have used him for my SMTA and H carbs. He did some work on the SMTA carb to get more power out of the tractor. It certainly worked. I easily one the points championship the first year after he did the carb work. I also cashed more checks at brush pulls than I ever have. The only things I changed were the carb, plugs and wires, and timing. I am POSITIVE the timing made a huge difference, but the carb had a lot to do with it.
I say I'm positive the timing had something to do with it because I pulled at a local pull and did bad. I then retimed the tractor and pulled the next day and cleaned house. With the tractor timed at TDC it didn't have near the lugging ability. I have NO IDEA how the tractor is timed. IIRC he advanced the timing quite a bit, but Pete will be able to straighten me out on that. I don't understand why advancing or retarding would change the lugging ability. Pete, if you can let me know the disadvantages of doing this I would appreciate it. I use the tractor on the plow and I don't really want to blow it up.
