Re: Float Height on a Super A Carter Carb?
Posted by Haas on November 19, 2000 at 16:45:45 from (129.37.117.18):
In Reply to: Float Height on a Super A Carter Carb? posted by Tyler (MD) on November 19, 2000 at 09:28:39:
Well, on my C with Carter Carb, I had trouble with it flooding. Gas would run out the drainage hole in the air line, and the tractor would hardly run. I thought the float was sticking, but apparently it was the float set too high and not shutting off the gas. I did not know where it was supposed to be set, so I guessed. Don't have a measurement, but I set it by bending the tab on the float that pushes up the needle valve so the float only had to move a small amount to close the needle valve. Now the tractor runs great and does not flood or leak any gas, although I still shut the gas off when it's in the shed.
Post A Followup
: Re: Re: Float Height on a Super A Carter Carb?
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
