Re: First Farmall
Posted by Matt Tieken on May 20, 2013 at 06:46:34 from (66.64.242.10):
In Reply to: First Farmall posted by Kevin Little on May 19, 2013 at 05:28:02:
That 3 point hitch looks like my Saginaw on the M. They are a good hitch for sure. They are good to talk to and have replacement parts if you break anything.
The only thing I would be mindful of is to make sure the mounting bolts are good and tight to the axle before you try and pick anything up with any weight.
Follow the link for some detailed pictures of the installation of a Saginaw 3 point hitch... http://www.rocketroberts.com/farmall/mgal-8.htm
Looks like a nice project.
This post was edited by Matt Tieken at 06:51:24 05/20/13 2 times.
