Re: No 8 3 furrow plow
Posted by Rdandersom on May 20, 2013 at 08:02:48 from (69.168.186.96):
In Reply to: No 8 3 furrow plow posted by Darald on May 19, 2013 at 21:56:47:
I am told that Canadian sold plows are slightly diferent.The #8 Tractor Plow doesn"t have the diagonal bar on the frame between bottoms and uses a 2 piece bar that runs perpendicular between the frame bars.It will be drilled to allow the furrow width to be changed.All IH trailing plows I have seen here in Ontario are made this way.Don"t know what else is different.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
