Re: No 8 3 furrow plow
Posted by Old-F20 on May 20, 2013 at 09:08:33 from (71.7.101.5):
In Reply to: No 8 3 furrow plow posted by Darald on May 19, 2013 at 21:56:47:
ive seen some canadian plows first hand an i can tell you they are a fair bit different. not sure how much will change over
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
