The pump shaft is driven by the timing dears in the front cover. This shaft has either a conventional lip seal, or an Oring. The shaft is usually grooved some from wear and the seal/Oring weak and worn. A speedy sleeve can be used on the conventional seal. (repair sleeve is a very thin covering that is put on the shaft to refresh the surface making a good smooth surface on which the new seal rides. The Oring version needs to have the seal hole in the housing enlarged and re grooved to fit a new Oring. Or bored out for a conventional seal. and speedy sleeve. Jim
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
