Posted by molzf on May 20, 2013 at 17:16:07 from (208.126.231.218):
I bought a '47 BN at an estate sale this past weekend. The carburetor is in pretty poor shape both on the outside and internally. It looks like a Zenith carb, but there is so much rust and buildup that I cannot tell what the number is.
In looking at some of the previous posts and the parts site on this webpage, I was wondering if it matters what type of carb I put back on the tractor, as long as it is meant for that tractor model? Are there any restrictions or issues with putting a different type of Zenith on, or even a Marvel? There are several options for Zenith and Marvel carbs that are supposed to work for a BN, so I thought I would check before I purchased.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa
... [Read Article]
Latest Ad:
[More Ads]
