Re: Float Height on a Super A Carter Carb?
Posted by Garnet on November 19, 2000 at 17:59:45 from (142.177.73.25):
In Reply to: Float Height on a Super A Carter Carb? posted by Tyler (MD) on November 19, 2000 at 09:28:39:
Tyler Specs for the Carter Model UT (used on C 123) Super C is 11/64" + or - 1/64" from gasket surface to nearest corner of float or 1 15/64" + or - 1/64" from gasket surface to lowest corner of float. Not sure if this is same for your model Carb.
Post A Followup
: Re: Re: Float Height on a Super A Carter Carb?
