Well, you can put 134a in the system and it will probably work fine for a year. Since you already have a leak, you will probably end up charging it next year anyway.
There are a few things that are recommended for the conversion.
I work for the company that makes Hot Shot (an R12 replacement) and can tell you that in order to use 134a, you should change the rubber seals and hoses to 134a compatible materials. You should also flush the lines and change the oil to a 134a compatible oil.
Whatever you do, pull a vacuum on the system before you charge it. You will never get the cooling you are looking for with the lines full of non-condensables (air).
If you want to, you can call our technical support line at 1-866-433-TECH and Jamey will help you out. Just tell him Matt told you to call.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
