Re: Farmall A Compression
Posted by old on May 21, 2013 at 09:03:16 from (209.86.226.56):
In Reply to: Farmall A Compression posted by kopeck on May 21, 2013 at 08:16:39:
Well with new rings but old sleeves that reading is probably about right due to sleeve wear. The compression reading you read is probably for a new engine as in new sleeves and matching rings. I will almost bet that the engine in my BA which is half B and half A has around that is not a bit less since I used all used parts to build that engine
