Re: Farmall A Compression
Posted by Janicholson on May 21, 2013 at 09:11:45 from (74.60.94.18):
In Reply to: Farmall A Compression posted by kopeck on May 21, 2013 at 08:16:39:
Several variables are in the mix of compression pressure. The following list is not complete.
Speed of cranking
Throttle wide open
Number of strokes for reading
Accuracy of gauge***
Warm or cold
Run recently (weeks) or not months/years
method of gauge attachment to hole
Your pressures are for sure in alignment with expected pressures on that engine. and close to one another. I would say no issue in those readings. Jim
*** gauges can be 20% different from perfect actual pressure, including both cheap and expensive gauges. Mechanics check their gauges against a master gauge periodically. Jim
