You should drain compressor and use Ester oil. Mineral oil and R134A are not 100 percent compatable but will tolerate some left over in system. I always install new filter drier. Sometimes new expansion valve. If cruddy system I flush, if not I just blow it out. Best to use nitrogen to blow as air has moisture in it. Just don't blow through new drier of course. You have to vacuum system to get rid of moisture and air. On those factory 66 series, you need to spend a great deal of time on cleaning the externals of that dirt infested condensor and make sure both fans are working good. Evaporator under roof may be full of dirt also. Have to be sure the evaporator is sealing properly also so air does not just go around in stead of through it.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
