Re: Voltage Regulator and wiring
Posted by John T on May 21, 2013 at 13:48:37 from (216.249.76.176):
In Reply to: Voltage Regulator and wiring posted by Jim Paterson on May 21, 2013 at 12:37:44:
BAT on VR up to the Load (NOT battery/starter)
side of Ammeter
FLD on VR to Gennys FLD post
(L)OAD on VR sends hot battery voltage up to
loads like Lights and/or Ignition via the BAT
input terminal on the switch
ARM/GEN as Teddy notes is often off on one side
or the bottom all by itself wires to ARM on
Genny
Polarize the Genny BEFORE you start up
Its possible to substitute a 3 for a 4 terminal or a 4 for a 3 terminal VR with only minor wiring modifications
John T
