Posted by farmallhal on May 21, 2013 at 17:24:52 from (76.0.44.84):
In Reply to: Parts for IH 240 posted by jd50A on May 21, 2013 at 08:23:29:
Both the IHC Farmall and International model 240's do not utilize a normal battery box. They only have a cover on the top which is next to impossible to locate (at least an original factory one) with a couple of angle pieces attached to the transmission that the battery sets on. The battery is secured in place with two long carriage bolts (one on each side of the battery) running vertically from the angle brackets and secured to the original factory cover to hold the battery in place. The steering wheel center cap is available from several sources as it was common to several IHC model tractors. I will leave the paint codes for the tractor to others as the correct paint is no longer available from the CaseIH dealerships. Wishing you well with your restoration efforts and your part searches as it will be a challenge as they both had relative small production quantities for an IHC tractor and few if any 240 unique parts are being reproduced to my knowledge, Hal.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
