Re: Farmall A Compression
Posted by gene bender on May 21, 2013 at 17:31:41 from (67.55.226.151):
In Reply to: Farmall A Compression posted by kopeck on May 21, 2013 at 08:16:39:
Thats a good reading. Do all the plugs look the same as that can tell a lot next would be wires and do you have a mag or a dist as worn bushings in a dist will cause problems. Just put a timing lite on each wire and watch for steady fire. Check each wire that way and if the dist or wires are bad it will show with intermitten fire.
