Re: '41 farmall A lift all hydraulics
Posted by Red Dave on May 21, 2013 at 18:35:24 from (65.199.61.119):
In Reply to: Re: '41 farmall A lift all hydraulics posted by J.Reece on May 21, 2013 at 18:25:02:
No, they are not the same. What you refer to as the "hydraulic pump" is most likely the touch control unit, not the pump. And it will not mount on an "A" torque tube. The hyd pump in low on the right-hand side of the engine block, below the distributor/magneto. An "A" block does not have the place to mount the hyd pump in the casting, unless it was a later replacement block.
The magneto, however would easily interchange between the two
