Re: Stuck bearing
Posted by gbs on May 21, 2013 at 19:57:01 from (64.234.38.41):
In Reply to: Stuck bearing posted by Harrison58 on May 21, 2013 at 16:14:41:
if your referring to the inner wheel bearing ,best way is with a good torch,first nick the roller cage and remove the cage and rollers,if you are steady handed start on the outer edge of the race cutting across the race wash it down to the spindle being careful not to cut into the spindle all the way to the back ,you can then tap it with a hammer and punch to easily remove it,trying to heat it up enough to expand it is hard to do because the spindle will also expand and heat up which i try not to do,with a little practice you can cut a nut off a bolt in the same manner and not damage the threads.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
