Re: Farmall A Compression
Posted by rustcollector on May 21, 2013 at 20:40:20 from (70.195.193.59):
In Reply to: Farmall A Compression posted by kopeck on May 21, 2013 at 08:16:39:
Compression pressure depends on a lot of variables including head style, piston head design as well as wear. A C113 engine to have 102psi would have to have a 6.9 compression ratio which is possible for a factory original gas C113; i.e step head pistons with a gas head. That is 100% efficiency for a 6.9 CR. To estimate what a compression test reading should be, multiply the compression ratio for the engine as equipped (piston design and head)by 14.7 psi which is one atmosphere pressure and then multiply by about 90%. If I remember correctly, the old distillate engines had compression ratios less than 5 to 1. That would put the expected compression reading to be below 70 psi and that engine will run like a top.
