the SA gas tank is not the same as the SC as the SC mounts different than the SA. You need the SA block and bell housing so you can mount the pump and rockshaft assy. SC had waterpumps and a taller radiator then the gas tank had different mounts raising it higher.I have a B that someone mounted all the stuff from a C made a new batt box and selded the B steering post on top so the controls for the hy system would mount. Cut the post so the height of the steering wheel would be like the B. They used a steering shaft from an A cutting it off so the u-joint clears the hy pump. Very neat job they then mounted a front mounted disc plow from a SA making the bracket so it would bolt to the B chassis.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
