Re: Stuck bearing
Posted by rustyfarmall on May 22, 2013 at 05:19:59 from (216.248.71.226):
In Reply to: Stuck bearing posted by Harrison58 on May 21, 2013 at 16:14:41:
If the bearing is good, and you want to save it, that bearing CAN be cleaned and repacked right there on the spindle.
