Good news and bad news. The good news is you found the symbols I sent you looking for. The bad news is I have never seen any listing for a symbol "F". Is there any chance there is a letter "A" in front of the "F"? If so, symbol AF is correct for a 504 with a gasoline engine. It was also on other C-153 engines (in 203 combine for example). If you find an "A" in front, there is your answer. If not, you can dig a little deeper. If you tear it apart, below the points plate are the centrifugal advance weights. They are mounted on a disk on the distributor shaft. That disk will be stamped for maximum advance and rotation direction. The AF distributor should be stamped 21L. If it is stamped something else, we can do some more looking to narrow down the possible distributor version.
The "E1" appears to be a date code, for May of some year that ends with a "1". 1961 would make sense for a 504 tractor.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
