Re: Need help Plow ID
Posted by CharlieU on May 22, 2013 at 16:59:27 from (216.188.209.61):
In Reply to: Need help Plow ID posted by Mitch D on May 22, 2013 at 05:41:24:
The plow that you are painting is a #16 heavy duty plow that was designed for deep tillage and could be obtained in 3, 4, or 5 bottom sizes, and in either 14 or 16 inch widths. These plows were convertible, that is the 5 bottom could be changed to 4 and the 4 bottom could be reduced to 3 simply by removing the offset rear bottom. Clutch lift or hydraulic lift was available as a customer option. The adjusting cranks were provided for leveling the plow and regulating depth. Production totalled over 8500 plows and were made between 1953 and 1965. I have a 3x16 hydraulic lift model.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
