Re: Need more hyd pressure on 1486. Can I get 3000 lbs?
Posted by Jim Naden on May 23, 2013 at 03:24:13 from (12.74.50.59):
In Reply to: Need more hyd pressure on 1486. Can I get 3000 lbs? posted by Larry B. 1486 on May 22, 2013 at 14:26:53:
You can get a 2500 PSI relief valve.
IIRC there is one IH application that used a 2700 PSI relief that would fit your 1486. Might have been a Doncaster built utility of some sort.
