Re: Need help Please! H won't start/stay running.
Posted by mkirsch on May 23, 2013 at 06:19:04 from (64.80.110.74):
In Reply to: Need help Please! H won't start/stay running. posted by jdp8402 on May 23, 2013 at 05:53:05:
It's not rocket science or magic. You *STILL* don't have a good connection to the battery.
Just "cleaning the connections" might not be enough. The cable may be corroded inside. The cable may be broken.
Test #1: Use one side of your jumper cables to connect the ground (positive) to the tractor's frame. If it runs you have a bad cable on that side.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
