Re: Need more hyd pressure on 1486. Can I get 3000 lbs?
Posted by pete 23 on May 23, 2013 at 10:53:16 from (74.47.40.242):
In Reply to: Need more hyd pressure on 1486. Can I get 3000 lbs? posted by Larry B. 1486 on May 22, 2013 at 14:26:53:
The 1486 came with a 2500 psi relief valve. First thing I would do is put in a known good relief valve as they will really fool you. Flow rating is the real answer to see if you are getting what the tractor is capable of . Then if you are you go for different larger cylinders. If not you repair tractor.
