Re: Need more hyd pressure on 1486. Can I get 3000 lbs?
Posted by IH fan on May 23, 2013 at 15:15:54 from (72.209.181.231):
In Reply to: Need more hyd pressure on 1486. Can I get 3000 lbs? posted by Larry B. 1486 on May 22, 2013 at 14:26:53:
If you have close to the spec 2500 cold and 2100 hot, you either need a new relief valve, or your old one rebuilt if that's possible. You shouldn't lose that much hot with a good rv.
