Re: Need help Please! H won't start/stay running.
Posted by farmallhal on May 23, 2013 at 17:15:26 from (76.0.46.224):
In Reply to: Re: Need help Please! H won't start/stay running. posted by jdp8402 on May 23, 2013 at 09:53:41:
I don't recall you stating where the ground cable is attached to the tractor in your earlier posts. If you attach it to the closest starter to frame mounting bolt you will have the best and direct route to a proper ground. All of my 6 volt tractors are grounded in this manner and I have no ground problems as all of the starter cables have been replaced with new 00 size cables with soldered terminals during restorations as well. Hope this helps your situation as well, Hal.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
