Re: Need help Please! H won't start/stay running.
Posted by old on May 23, 2013 at 18:28:58 from (209.86.226.58):
In Reply to: Re: Need help Please! H won't start/stay running. posted by jdp8402 on May 23, 2013 at 09:53:41:
If you buy new cables make sure they are 0 or 00 sized cables being it is 6 volts. If the switch is questionable then try a hot wire from the battery ignition side to the ignition side of the coil. Doing that will tell you if the switch is bad or if you have loose or broken wire some place
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
