That is definitely a Torque Amplifier lever. BTW, torque amplifier is a two-speed "powershift" that gives you two speeds for each gear.
The reverser lever is a simple rod with a ball on top IIRC. It goes "over center" for forward or reverse.
Sit in the seat, drive around, and try the levers. 100% guaranteed that none of the levers are for an ejector seat, and there are no guns or missiles or self-destruct. You will be safe.
If you are really antsy about it, make sure you are in an open area when you start playing, and make sure you know how to shut the tractor off with the key to make it stop if things get out of hand.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
