Re: IH 2504 What are all these levers?
Posted by karl f on May 24, 2013 at 05:35:43 from (172.162.231.178):
In Reply to: IH 2504 What are all these levers? posted by ja1724 on May 23, 2013 at 17:03:43:
I see you have a hydraulic remote valve with broken off lever and no pipes plumbed to it. It looks like you have a small red arrow pointing it out in the top picture. hopefully the missing plumbing has plugs in its place on the valve. once you find a lever and get new couplers and plumbing (hydraulic hoses+fittings) you can lift a pulled implement. It looks like your loader is powered with an external pump, maybe off the crankshaft?
We'd like to see more pictures of your tractor and if you have more questions we'll all try to help. There should be plenty of tin available to replace what's missing from salvage yards. a 504 should be 95% the same tractor--if you stick to utility models.
karl f
