sry on the wait. I use the widest point/spray pattern available. Depends on your rig, some have interchangable tips, my new Brigss & S has an adjustable fan tip. Use widest. If that is not doing the job - get closer. You want to get under the edge, so come from different angles (left then right). NEVER SHOOT UP! If doing standard clapboard, you may have plaster and a big mess inside! NO joke, been there. ON outbuildings, maybe watch for feed bins, old electrical etc. Hold at about 45 degree angle,approach from about 6-12 inch out and come in to about 2-3 inch. Do not come straight in as this will probably leave "gauges", sweep in from the side. 20 minutes practice will tell you more than I can here. You will consume water. Plan for that. You really want to get off the dry rot as well as the paint. I will post pic's if I can. Hand painting oil primer will ensure that all the rough edges are covered, or far better than spraying.Just does a far better job of sealing up the edges. Top coat can be sprayed. HEAT GUN -only for really ugly details in very high visability spots,like main door trim to house. Be very careful, I use the air gun type from harbor freight, $10. Heat only to point that you can scrape off, 10-15 seconds. BTW-this type of heat gun can be used for other stuff, life frozen doors locks, softening up heavy grease, etc ps- the single point on your high pressure washer will cut through your walls very quickly. I use mine for digging holes for pole barns,no joke.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
